with out button press .event should occur once
Hi make me clear where i need to write false in Event case or in Button.Can u say clearly how to do it
Message 11 of 15
(676 Views)
See the attached VI.
- Partha ( CLD until Oct 2027 🙂 )
Message 12 of 15
(673 Views)
Hi u r example is working fine if i create val(signaling) property it is in purple colout how i can make that to change to green
Message 13 of 15
(661 Views)
Latch action booleans are incompatible with local variables and value properties for good reasons.
Use a switch action boolean and reset it to false inside its value change event via a local variable.
Message Edited by altenbach on 09-23-2008 09:54 AM
Message 14 of 15
(648 Views)
See here. I ve already explained. Smiley Wink
Message 15 of 15
(635 Views)
