wm_queryendsession
How can I read out the WM_QUERYENDSESSION?
I want to close my App (LV 5.1.1) on Win 9x, when Windows gets an exit windows command.
(4,089 Views)
You can follow the link below to download the Windows Event Queue VIs. You should be able to use these VIs to catch the wm_queryendsession message in labview. WM_QUERYENDSESSION is = to 0x0011 according to the readme file.
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/9fc2504965ce8197862567f600638e94?OpenDocument
(4,089 Views)
Thank You very much.
I tried to catch the wm_queryendsession. But it didn't work. I think the runtime closes because of the wm. So the LabView-Application closes without read the wm.
(4,089 Views)
wm_queryendsession is for shutting down the computer, in case you thought it was for closing the window.
I'm still puzzling out how to intercept the 'X' button, though.
(4,089 Views)
