(wm5) windows.h missing along with other C or Vi libs during Build
Hi..
my OS is Win2003 Enterprise
First, I installed LV PDA 8.0 with eVC 4 with SP4 and was able to build a project .. however, had an error with windows disabling "Virtual Network Machine Driver" associated with the Emulator
Then I installed VS 2005.net/DCS.. .applied lv pda 8.0.1f
then maintenance release 8.0.1 and mass compiled
Current Status, all pda projects use the new EMulators, however, fail to build because of missing .. .h files / C files..
i tried to re-apply the lv 8.0.1f and then re-mass compile ..following the guidelines.. however, no difference
Thanks for your help
Maged Fawzy
(2,926 Views)
Hello Maged,
First of all I would just like to mention that the Windows 2003 Server OS is oficially not supported by LabVIEW. You can look at the release notes for LabVIEW at this location.
The issue that you are facing is actually Microsoft related. Kindly look at this knowledgebase from Microsoft for more information. Although this KB refers to XP, but it might hold applicable to your case also.
Chetan K
Application Engineering
(2,907 Views)
