wonder whether Labview6.1 program can install wif web cam?
I am using SCB-68 DAQ device with windows 98. Is it possible to install LabView program with webcam so that it can show the waveform online.
(2,690 Views)
If all you want to do is show something, there's no need to have a web camera pointing at the monitor. LabVIEW has the ability to publish an HTML page of the VI using the built in web server and no programming changes to the VI itself. The Web Publishing Tool is under the Tools menu. Look up "Web, publishing VIs" in the on-line help. Click on the link "create an HTML document" for a step-by-step procedure. For viewing options, you'll probably want the monitor type.
(2,690 Views)
