woodward easYgen genset controller via modbus
Hi all,
I have a labview program that reads a single parameter and I am trying to modify it to read multiple parameters. I am very new to Labview and I am struggling. can anybody help I can email you ther program i have, on request.  If anybody wants to contact me dirrectly u can at rcarscadden@hotmail.com.
Thank You,
RayC
(4,043 Views)
Why don't you post the code over here (or maybe a snapshot of it), explain to us the issue you are facing and we can help you out?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,042 Views)
i have attached screenshoots of the Vi
thank you
RayC
(4,032 Views)
One issue I see in your code is that you are using commands 4 and 6 to read or write registers.  But you are getting the data out from the "Discrete" element of the cluster rather than the registers.
If you are reading booleans, AKA "coils", you should be using codes 1, 5, or 15.
Also, rather than using a 0 or 1 numeric control and a case selector to define read or write, why not use the Enum that is part of the Modbus Data Cluster?
(4,019 Views)
I have been told it is possible to write a config file in labview to read in all the parameters I need. Is there a simple way of doing this? Or any tutorials i can follow?
(4,002 Views)
