works in debub/highlight mode but fails in real run
Attach the vi instead. What's the point if the sequence on top?
We tend to question code with stacks of stacked sequences.
Message 11 of 24
(2,518 Views)
Here is the VI. The top sequence is useless, i just used it to keep my controls and indicators etc tidy and makes easier for me to access them as I intend to create/use property nodes often.
Message 12 of 24
(2,514 Views)
You cannot simultaneously declare something "useless" and then argue it's usefulness!
Obviously, you must be a text programmer. 😄
Message 13 of 24
(2,508 Views)
Not everybody is LabVIEW champion!
Thanks for the valuable input and identifying me, altenbach.
Message 14 of 24
(2,503 Views)
But some of us areSmiley LOL
try this mod
When it works I'll tell you what you did wrong
Message 15 of 24
(2,489 Views)
Thank you for taking that well.
Spoiler
When I first read Christian's post I thought it was borderline insulting.
Ben
Message 16 of 24
(2,488 Views)
Can you please save in LV 2010 version, this 'text programmer' cannot open your 2016 version. Thank you so much for the help.
Message 17 of 24
(2,486 Views)
OOPS
in 2010
And, if I'm right, you all are going to get laugh at how Highlight execution actually effects the operation
Message 18 of 24
(2,484 Views)
Hi Jeff
Thank you for the compatible version.
however the modification does the same. the current field doesn't reset after the completion of for loop and operation goes beyond the endfield value. I compared with before modification VI and could not find any change.
Message 19 of 24
(2,479 Views)
Wel come Ben, yes, it is bit insulting and may be that is why you gave 1 kudo. Smiley Happy
Message 20 of 24
(2,478 Views)
