wrap phase
Labview 7.1
       It has the functiong for unwrapping phase.
       But, now, I need to convert an array of phase data to range -180 deg and 180deg (wrap?).  Is there any way to do that easily or any algorithm?
Thanks.
Weitong
(4,762 Views)
You can use the Quotient & Remainder function. using a for loop, let x = your array element and y = 360. The Remainder will be your wrapped phase ( 0 - 360 ). Add -180 to your remainder.
Message Edited by Phillip Brooks on 04-09-2008 07:55 AM
(4,738 Views)
I had to do the same thing a few years ago...basically I wrote my own function in a formula node. That code now belongs to the people that hired me for the task, so I don't have the code to send you, but it was a pretty simply
 int32 y;
if (x >180)
     y = x -180;
else if (x < -180);
     y = x +180;
else
    y = x;
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(4,735 Views)
Thanks.
(4,705 Views)
