write 1d cluster continuously in csv
I would like to know how can i write the 1d cluster in . csv?
Message 1 of 18
(5,847 Views)
Hi josi,
what does the cluster contain?
Which data format/layout do you need in your CSV file?
Message 2 of 18
(5,843 Views)
 it contains 2 double and 1 array
Message 3 of 18
(5,835 Views)
Hi josi,
unbundle the cluster, prepend the scalar DBL values in front of the array.
Do this for each cluster and you will get a 2D array. Save that 2d array in your csv file…
Message 4 of 18
(5,826 Views)
I would use a FOR loop to create an array of strings, an element for each line that goes in your file.  Format Into String would be useful here.  Then use the Write Text File to actually write to the file.  Open/create your file before your loop and close it after the loop.
Message 5 of 18
(5,821 Views)
i' ve tried this but my vi write 2 datas only
See the file
Tks 🙂
Message 6 of 18
(5,813 Views)
You need to wire a True to the Append to File input of Write to Spreadsheet File.vi. As you have it configured, it overwrites the old data on every iteration of the while loop.
Turn on the context help window to get more information.
Lynn
Message 7 of 18
(5,806 Views)
You haven't wired the y array to anything. There's also no real reason to convert everything to strings. You can write all as dbl.
Message 8 of 18
(5,788 Views)
i did the conversion because i wanna add another sring with the names of the colums
Message 9 of 18
(5,775 Views)
Ok, stop using the Write To Spreadsheet File VIs.  Use the actual File IO API.  This way you can create the file, write the header data, write data continuously in the loop, and then close the file after the loop.  It will make things a lot simpler and a lot more efficient.
There is also no need to wire up the N on the FOR loop since you have an autoindexing tunnel that will tell the loop how many times to iterate.
Message 10 of 18
(5,766 Views)
