write a character string and find the number of vowels in it
@Eric1977 wrote:
I didn't know that not placing a replacement character can slow it down. I'll keep that in the memory bank for the next time I use it.
Same.  Kudos for the tip!
-Kevin P
Message 11 of 20
(1,450 Views)
@Eric1977 wrote:
wiebe@CARYA wrote:
However, if you set Search and Replace String to match a regular expression:
It count the replacements out of the box.
Note that I replace with a character (any character will do). If you don't wire the replacement, the string will be shrunk for every replacement, slowing things down.
I guess it gets more complicated if you add "sometimes 'y'".
Bill
CLD
(Mid-Level minion.)
Message 12 of 20
(1,443 Views)
Yes, but not by much:
Since the entire match is a capturing group (the first) we can replace the match with itself (indicated by "$1").
Message 13 of 20
(1,400 Views)
But "y" is only a vowel (in the US) under certain conditions.
Bill
CLD
(Mid-Level minion.)
Message 14 of 20
(1,389 Views)
Ah, didn't know that.
That would make a funky regex.
But if there is one online, it will work.
Here's a discussion about vowels vs consonants regex's, but I don't think that covers it all: Regex - matching world which contain only vowels or consonants - Stack Overflow
Message 15 of 20
(1,385 Views)
I never thought of that.  Someone, somewhere probably made a regex for that!
OMG here's what ChatGPT came up with:
[aeiouAEIOUYy](?<![aeiouAEIOUy])[aeiouAEIOU]*$|(?<=[aeiouAEIOYy])y(?![aeiouAEIOUy])
Explanation:
  • [aeiouAEIOUYy] matches any vowel, including 'y' in both lowercase and uppercase.
  • (?<![aeiouAEIOUy])[aeiouAEIOU]*$ matches a vowel (excluding 'y') that is at the end of a word or syllable. The (?<![aeiouAEIOUy]) is a negative lookbehind that ensures there's no vowel or 'y' before the vowel we're matching.
  • (?<=[aeiouAEIOYy])y(?![aeiouAEIOUy]) matches 'y' that is surrounded by vowels (including 'y') in the middle of a syllable. The (?<=[aeiouAEIOYy]) is a positive lookbehind that ensures there's a vowel or 'y' before the 'y', and the (?![aeiouAEIOUy]) is a negative lookahead that ensures there's no vowel or 'y' after the 'y'.
Bill
CLD
(Mid-Level minion.)
Message 16 of 20
(1,378 Views)
Explanation:
At a glance, it looks like it will check a word for vowels.
It doesn't seem to check vowels in a text. Or at least I don't see anything related to word barriers.
Message 17 of 20
(1,375 Views)
Explanation:
The rules I gave it related to a single word.  I forgot about that.
Bill
CLD
(Mid-Level minion.)
Message 18 of 20
(1,367 Views)
Explanation:
AI or not, it's still a computer 😂...
Message 19 of 20
(1,348 Views)
Explanation:
I know.  It did exactly what I told it to do, which may or may not be what I wanted it to do.
Bill
CLD
(Mid-Level minion.)
Message 20 of 20
(1,310 Views)
