write a comment to a file
I achive a signal and I want to save it on a file.
I want to insert a comment when I want during VI running and not to stop VI change comment and restart.
I find this method in the file attached but I want to do other thing:
1- Change the file when I write a comment
2- Name the new file with the comment string
3- don't use a button from FRONT PANNEL to reset VI, but a key of keyboard
please help me
thank you
Marco
(3,859 Views)
action when keyboard pressed:
1) you can set the focus active on the e.g. stop button - using the proberty node - when you press enter the value of the stop button will change.
2) you can set a shortcut to the button, in front panel: right mouse => advanced => key navigation
now your other questions:
why you want to change the file when you write a comment?
and rename the new file?
i think for this you must use the file name field
(3,857 Views)
