write analog signal waveform and digital signal wavefom to the same tmds file
I want to write analog signal waveform and digital signal wavefom to the same tmds file.How to deal these two kind waveform to satisfy the data type of the function"wirte tmds"?
(3,218 Views)
Either you convert your digital waveform to a analog waveform (using DWDT Digital to Analog.vi) or they other way round.
Then you combine them with build array.
Christian
(3,176 Views)
