write array data to file
Here I have a problem to save a 2D array data to file. Please see the picture Save array.jpg , on the Left side is my array data in hexadecimal code and on Right side is desire saving file.
I have try to using the writing to file vi to perform this saving function, but not same as my desire condition. I have using the the Save array.vi function to save the data, and the actual is result.doc. Totally difference from my requirement. Anyone can give me the advise why I can not achieve my target???
(3,494 Views)
You cannot write a 2D array if each line needs to start with a ":", you need to write it line by line.
Attached is a simplified version (LabVIEW 8.0), I am sure you can adapt it for your purpose. 🙂
(3,489 Views)
Hi Altenbach
I success to save the file as I want. Thank you very much.
Can you please tell me what is the timer rule delay for 500mSec?
Thank you
(3,480 Views)
Sorry, I don't understand your question. Please explain.
(3,474 Views)
Hi Altenbach,
Sorry, I have make a mistake, because I open a difference file.
Thank you for your help.
(3,471 Views)
