write comment and headers to spreadsheet file
I am using Labview 2010 to run IV measurement. After getting IV data (2D array), I am using "write to spreadsheet file.vi" to save my data. However, I want to add some comments and time&date into that file. How can I do that?
Joyce
Message 1 of 8
(5,920 Views)
Use either Write to Text file, or another Write to spreadsheet file (string format) before that.
Message 2 of 8
(5,915 Views)
Have a look at the attached VI.
Nitzz
(Give Kudos to good Answers, Mark it as a Solution if your problem is Solved;))
Message 3 of 8
(5,906 Views)
Thanks.
I have another question when I convert number to string.
So my comment string is like: Voc(V)  0.511.
The number 0.511 is calculated from measurement data.
So I am converting this  number to string by using "number to fractional string", then using "concatenate strings" to concatenate string "Voc(V)", then use "Write to text file" to append to the file. However, the final result came out like this: "Voc(V) 0.000000"
Why is that?
Joyce
Message 4 of 8
(5,863 Views)
hanks.
Why is that?
Joyce
Message 5 of 8
(5,862 Views)
See the attachment.  What do you get at the output of the concat string?  Is it 0.00 at that point?  Post your code if you are able.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 6 of 8
(5,856 Views)
Here is my code. I concate all my comments about Voc, Jsc, FF,efficiency etc and then write to text file. the final number which I have converted to string came out as 0.00000.
Joyce
Message 7 of 8
(5,845 Views)
You almost certainly have race conditions caused by the use of local variables.  The Jsc and other local variables are probably read as soon as the loop starts an iteration. The values written to the indicators occur near the end of each iteration.
Solution: Remove the local variables and wire the data directly.
Read up on all the problems locals can cause.  If you have not done so, work through the LabVIEW tutorials.
Lynn
Message 8 of 8
(5,836 Views)
