write data from different sequences to seperate tabs in lvm
In every sequence I have data to write to an lvm.  I want the data from each sequence to be written into different tabs (worksheets) in the lvm.  This way I have one file every time I run the VI but the data from the different sequences is seperated.  Thanks.
(2,397 Views)
There is no such thing as worksheets in an lvm file. It is a text file. In order to write to different worksheets, you need to write to an Excel file. This requires ActiveX and the Report Generation Toolkit or you can write your own functions. I would suggest looking at the Excel example that ships with LabVIEW and then looking at the examples posted to the Excel board.
(2,387 Views)
