write data into several channels.
Hello to everyone, 😉
I have a problem with writing data to a file.
I am trying to write a 2D array of single (containing 3 different signals) to a LVM file,
but for some reasons the Data is saved as three samples of one channel, I have not been able to set it so that it splits the data into three different channels. Anybody an idea how I can switch this?
The incoming 2D array looks good to me.
Thank you very much in advance,
Keksbold
(2,721 Views)
Accepted by topic author Keksbold
Assumption: Each row of your data is one channel of N samples. Your 2D array should go through a "Convert Dynamic Data" vi. Right click on the "Convert Dynamic Data.vi" and choose: "2D array of scalars - rows as channels".
Or post code if that isn't helpful.
(2,700 Views)
*facepalm
I should have thought about that myself...
Thanks a lot for putting me in the right way!
Keksbold
(2,680 Views)
