write data to analog channel from RT vi
How do i write data to analog channel from RT vi? can i configure analog channel to use it from RT code.?
Thanks you,
Ranjith
(2,670 Views)
What kind of hardware and software are you using? How have you setup your entire system? Have you had a look at some example code?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,655 Views)
I have PXI with R series FPGA card in it. I have the floating point data and time. i have created interpolation data with delta 20us.
can i write the data to analog channel from RT vi without writing FPGA vi?  what is the best way to write it to analog channel?
(2,650 Views)
