write different values to DAQ
Thanks crossrulz
How can I add them together?  One of them is a waveform and the other one is just a number and I don't want to miss any data
Message 11 of 14
(472 Views)
If one is a waveform, then the other is a waveform as well. As I already said, just make every value in the waveform the same value. You've been shown how to do this as well. You should be setting non-regenerative mode if you need the ability to change values. See the shipping example.
Message 12 of 14
(463 Views)
DId you not notice my last VI where I created a 2D array?  The first row I designated as the waveform and the second row was the DC.  I used Initialize Array to set all of the data points for the second waveform to be the same, making it a DC signal.
Message 13 of 14
(447 Views)
I think you might wanna try this example,
there you can generate two (sinewave or other) waveforms, and change their parameters while running. I think you can set the amplitude of one waveform into "0", then you will have "DC Generation" just by changing the offset value.
regards,
Yan.
Message 14 of 14
(435 Views)
