write hex number string with some MSB padded with "0" to csv file
I am trying to write some hex value string to csv file, this value need to preserve the MSB "0" values.
For example,
Hex value = 00FF00
if I save this value using Labview "Write to Spreadsheet file VI",
I will loose the two prefix "00", it becomes FF00 in the csv file.
Can any show me how I can save this as "00FF00"
Do
(2,825 Views)
They are already formatted, so you should go upstream where the formatting occurs. There use %06x as format. Can you show us the rest of your code?
(2,821 Views)
