write key stroke combination as strings to get the output as string
I wonder If there's a way I can use key stroke to generate an "M-Dash" string. For example, If I insert into a constant string "Alt+0151" then I get "—" as output string
(2,341 Views)
Here is a–z (I used an n-dash, which is the proper punctuation for a "range").A to Z.png
Bob Schor
(2,285 Views)
