write number
hello everyone,
here is my problem. I am doing an experiment where i measure temperatures. I have a burner using methane and i have 3 different volume flow levels. 5-10-15 litres/sec. The volume flow is controlled manually and has nothing to do with labview. what i want to achieve is: while i am running labview to measure temperatures i want to have the ability to write in a cell somewhere the number 5 and that 5 to be written in my file with all the data as a second column right next to the time. After a while when we change the volume flow i want to write 10 and that 10 to be written again in my file. so what i want  to do is shown in the picture below.
thanks in advance 🙂
Chris
(4,244 Views)
What have you tried?  Post a snippet of your code.
aputman
(4,227 Views)
Sounds a lot like a table control to me.
(4,192 Views)
Use table Control to Display data and use Write Delimited Spreadsheet to save in a File
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,168 Views)
my experiment consists of 2 codes. one using niDAQ and 1 using agilent. to write the data from the NI I use write to measurement and for that part I have solved my problem. I don't know how to do the same for the agilent part where I don't use the write to measurement command, but simple read,write close files. I attach the code below.
(4,151 Views)
Share the code in Lower version (LV 15)
(4,138 Views)
