write result to excel file
I try to write my test result into a excel files:
The test result is two column, pls see example attachment, one column is :1 2 3..., another is 100, 200,300....
But above the result, I also need to put some information about the test, in the example, it's: measure result , parameter1, 2 ,3..
So how can I write the result to excel files and have the information.
(2,677 Views)
Hello srt,
I would prefer to write to csv-formatted text files. Excel can handle them...
Hope this helps.
(2,669 Views)
