write to a spreadsheet file
Hi
I am trying to extract some data from different file types and want to write it to a spreadsheet file. I very well know to read the data from txt file or lvm file and write to spreadsheet but my problem is if I have a file with some other extension (not .txt or .lvm).
COuld you guys please help me what logic i have to use in this case.
Robin
(2,388 Views)
It depends on the type of file.  For example, if you have a format like XML, you can read it as text and use some of the XML tools to help extract data.  If you have a complicated proprietary format such as XLS, it may not be worth the effort to attempt to extract data from it directly.
(2,385 Views)
