write to a text file
hello all
this is a really simple question.. but believe me or not i cudnt find a solution to this.
whenever i m running the vi, it does run without any problem but when i open the text file where it is suppose to write the data.. the textfile is unreadable. there r some symbols and no numbers.
i m attaching the vi.
can someone plz tell me where is the problem?
regards.
(3,111 Views)
rdas,
You need to convert the numeric value to string first.
I'll modify your vi & post it.
RayR
(3,107 Views)
Here it is..
I added carriage returns to make the numbers more readable.
There is a better way to do this if you do not have to write to the file for each iteration of the loop. (Let me know)
RayR
(3,106 Views)
thanks very much joelabview. this is exactly what i wanted. actually this vi is just a part of a bigger program.
but somehow i was messing up this part.
regards.
(3,104 Views)
Glad it solved your problem.
RayR
(3,099 Views)
