write to file adds spaces to lines??? help pls.
    I've attached a simple little VI to write some text/etc. to a file saved as "C:\test.txt".  I'm having trouble understanding the output shown below:
2:05:51.608 PM 10/27/2006
where does this go?
test1
 343.090000 test2
 TRUE
specifically - I want to know why lines  4 and 5 are indented one space??/
any explanation is appreciated.
thx
-Z
Message Edited by zskillz on 10-27-2006 02:49 PM
(2,551 Views)
Right-click on your "write" node and select "edit format string". Now remove any spaces you don't like and OK it. 🙂
(You see that by default, format codes are seperated by spaces).
(2,546 Views)
GARRR!
that is really annoying!  thanks for the help w/ that altenbach
-z
(2,534 Views)
