write to measurement file refuses to save
Hi, I am currently develloping a reactor that needs to log temprature ans other parameters.
I am at the early stages of the devellopmen. For the temperature we are using analog inputs that are convertedto a digital signal by a Cole-Parmer A/D convertor. I need to log this signal and therefore I am trying to use the Write to measurement file VI. But when i run the program the VI refuses to save my data in a lvm. file
(2,721 Views)
Are you saving the file in a directory you don't have access rights to?
How does it "refuse to save"?  Are you getting an error message?
Right now you are only trying to save a single value to the file since you are passing a scalar value out of the loop when the loop ends.
(2,720 Views)
i'm not getting any error messages, but i've put an indicator that indicates if the VI's saves and it's off. I tried it whit the signal simulator and it worked just fine so i think it has something to do with the scalor value or me putting the VI outside the while loop
(2,683 Views)
In your code, saving happens once the loop stops. That's dataflow. If you want to continuoulsly save during execution of the loop, the "save" code belongs inside the loop.
(2,676 Views)
Thanks, that was the solution!
Sorry for bothering you guys with this simpel problem.
(2,644 Views)
