write to measurement file vi bug?
I just checked, within LV2009 on Windows it's within the quickdrop.  What version/operating system do you have?
Dominic Walker
Cardiff University
Electrical and Electronic Engineering Student
Message 21 of 30
(2,838 Views)
I found it at my system under file I/O as mentioed 🙂 Win 7 LV2009 sp1 thanks 🙂
Message 22 of 30
(2,835 Views)
I do have it under File I/O.  It's just that the search never showed it.  It does show in quick drop.  It just happens that when I went to look for this (actually I originally looked for Empty Path thinking that's what it was), I used the search tool rather than Quick Drop.
(Win XP, LV 2009sp1)
See attached.  The search for Not a Path gave me the dialog to the left.  When I clicked on the Not A Path constant, it took me to the palette location shown on the right.
Message Edited by Ravens Fan on 03-04-2010 11:19 AM
Message 23 of 30
(2,828 Views)
Raven's Fan You must have edited your palettes
Message 24 of 30
(2,812 Views)
No.  As I said, I do have that constant under the File I/O palette.  See attached.  I have not done any palette editing.
The problem is when I use the Search button at the top of the palette to try to find "Not a Path", the one under File I/O does not show up as a result, only the constant that is under 7.x >> OpenG palette..  (See the earlier attachment)
Message 25 of 30
(2,809 Views)
I see this bug still exists in LV 2009 SP1. Has abybody found a solution for this issue?
Thanks!
Message 26 of 30
(2,506 Views)
Did you look at the message that was marked as the solution?  http://forums.ni.com/t5/LabVIEW/write-to-measurement-file-vi-bug/m-p/1020325#M454941
The bug was fixed in LabVIEW 2010.
Message 27 of 30
(2,500 Views)
What is the name of the box that is connected to the "f" input of the "Select" function:
Also I do not want the user to specify the filename; I want to set the filename and the path in the properties of the Write to Measurement File VI. How will it work in this case?
Message 28 of 30
(2,496 Views)
It is the Not a Path function.
Create a path constant rather than a path control and feed that into the True input of the select function.
Message 29 of 30
(2,487 Views)
Yep, it works as you suggested before. Thanks!
Message 30 of 30
(2,471 Views)
