write to measurement
When I press the button SALVAR is not creating sequence of files.
Tks
(3,050 Views)
I got do save in multiples files.
I just checked "after n segments"
No my problem is...how can I save both data??? number 1 and number 2 to files...because lately I want use this values in another VI
tks
(3,041 Views)
Wire a True constant to the "new file" input.
Message Edited by smercurio_fc on 05-05-2008 11:06 AM
(3,031 Views)
I used merge signals to do that and it worked.
It is saving all data in the file.No problem.
My question is...after save data in file...can i rescue all data and insert in istring indicator or numeric indicator??
tks
(3,005 Views)
Yes, just use the Read from Measurement File Express VI. You will need to configure it to complement how you were writing out the files.
(2,996 Views)
