write to mesaurement file error
Okay, this question has been asked various times with different solutions but nos of those solution seems to help me.
I start the VI, begins recording automatically wihtout any problem, it creates the file and the folder etc... but when I pause the recording and then unpaused it shows the following error and shows no path
this is the block dia.
Like I said, I tried different post it solution and nothing.
Roddy
(2,776 Views)
You will need to keep up with the file name and send it through when you restart your code. I would also make sure that it is not getting reinitialized when you restart it.
Tim
GHSP
(2,761 Views)
