write to network analyzer HP8753D
I need to write some known data to the memory of HP8753D so i can perform a data/memory calculation
I downloaded the drivers for the analyzer but it only has a driver to write strings. Does anyone has a driver that could help me to write and plot in screen.
(2,982 Views)
I'm not sure what you're looking for. There's the function Save/Recall Data and a Data to Memory function that apparently will recall saved data. Can't say how well it works. If that's not the function you're looking for, could you explain in further detail what instrument command you need to implement?
(2,982 Views)
Thanks Dennis,
I didn't see that vi before , it is actually what i was looking for.
(2,982 Views)
