hello,
I need to write to the digital port and the serial port at the same time. Right now I have the two vi's (to write to the serial port, write to the digital port) in the sequence structure. First I write the digital port, then write the serial port. Using the oscilloscope, the interval between these two executions is 10 ms; and I need to reduce this interval to as small as possible. I would appreciate help in any way. Thank you.
