'write to spreadsheet' VI error: File already open
I get this error when I am writing to a CSV file: I record data there continuously... well I have programmed that it stores about 100 points in the memory and writes every 100 points.
When I open the recorded file, for example in notepad to preview it, Labview returns the error "File is already open" and hence it cannot write.
Isnt this weird? Arent you just caching the file info when opening? How do I solve it?
I am using the 'write to spreadsheet' VI.
Message 1 of 11
(6,802 Views)
No it isn't weird.  Notepad has the file opened.  How can Labview open it for writing?  Can't be done.  Close Notepad before running Labview.  When you want to view the file, pause Labview, open the file with Notepad, then close Notepad before resuming Labview.  A big pain! Smiley Mad
The workaround is to create code in labview to read the file and display the contents in an indicator.  Then you can see the new writings on the fly.
- tbob
Inventor of the WORM Global
Message 2 of 11
(6,797 Views)
An alternative is to use Notepad++. It caches the file it reads, so you can still write to it. If you switch application focus from Notepad++ and then back into Notepad++ then Notepad++ will detect the file has been updated and asks if you want to reload it.
Message 3 of 11
(6,779 Views)
... Or just do the old fashioned thing, copy the file you want to check, open and view the copy and continue to write to the original.
I haven't had problems with this method yet.
Funny how this error never appears for me in my config file code. (Maybe beacuse I have all the file data cached in a FGV I can just write all the data to the file again whether it is opened by notepad or not!) Smiley Wink
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
Message 4 of 11
(6,767 Views)
What is Notepad++?  Does it come with some version of Windows?
- tbob
Message 5 of 11
(6,757 Views)
No, it doesn't. It's a free editor designed to be a replacement for Notepad.
Message 6 of 11
(6,754 Views)
Notepad++ looks good. Thanx,
- tbob
Message 7 of 11
(6,740 Views)
Guys, thanks for the replies.
As a matter of fact I dont WANT to see the file when writing. But I'm building a commercial app and it will probably happen once or twice when users will try to open a file that is being written to.
So if I cant avoid the error when opening, maybe I can prevent the user from opening the file by setting permissions? I will try this and report. Other suggestions are welcome.
Felix
Message 8 of 11
(6,722 Views)
Accepted by topic author _Faust
Perhaps when you get the error, store what you were going to put into that file into memory or a temporary file.  Pop up a dialog that doesn't halt your program telling people not to open the file.  When your program detects the file is no longer open giving the error, then write out all that you stored in memory (or read from the temp file and write it out) before appending the newest data to the file.
Message 9 of 11
(6,714 Views)
I really like your solution, thank you for your input. Will do so!
Message 10 of 11
(6,698 Views)
