write to spreadsheet file issue and in sampling rate
Hi to all,
      I have created some vi to acquire a signal and save it in a csv file but when i was analysing it, at the 0th sec , the values which it was acquired is displayed in a same array that time label displayed but at the 1st second it displays in a next row of the array, i don't what was happening?, i need some ideas to clear the issue and also at the sampling rate when i was increasing it to 1000, there is a time lag to get the results, the project i deal with this is lvdt analysis, when i was moving the lvdt i need to see the voltage variations but at the high sampling rate there is a time lag to get the values and display it in a xy graph i was using NI usb 6211, need some ideas.
Thank you in advance,
Dinesh
(2,490 Views)
Hi dinesh,
Why do you write the very same data again and again in your data saving loop - until there is a file error!?
THINK DATAFLOW!
(Did you even try to debug your VI using highlight execution and probes???)
- Why do you place AI and AO task in the same loop? Separate them!
- Building bigger arrays in the DAQ loop is quite often a performance killer!
- Reading/writing property nodes might also decrease execution speed!
(2,477 Views)
Hi everybody,
     I need some idea to save the acquired file in csv file, however i need to do it in a different way, the acquiring data in a vi is saved in a csv file at the same time the header details for the acquiring data is created in a another vi now i need to append the both details in the same csv file and also i need some ideas to put a logic it is without entering a header details the acquired data vi should not start, which one is the best way to do?, i have attached my vi to this for further clarification and also at the same time how can i transpose header details, so that name and reg details would look vertically.
Thanks in advance,
Dinesh
(2,446 Views)
