write to spreadsheet file path
I have a program that uses the write to spreadsheet file.vi as shown above, in the beginning of the program (left) it is meant to set up all the headers and then at the end (right) store the data to the same file path (thus the local variable).
I noticed if I don't specify a path and i let it prompt me for one, it doesn't store that location, instead it will prompt me again a second time (when the program gets to the write to spreadsheet on the right) and it will save to a 2nd file, even though I use the local variable.  Is there a way around that?  Maybe if I just wire it directly (w/o the local variable) it will keep it in the same path?
(5,354 Views)
YOU are not storing the location. You should be using the path output of the function and wire that to the next instance.
Stacked sequence and local variables. Not exactly a robust architecture.
(5,353 Views)
So I can just wire it directly then and that should fix the problem.
Whats wrong with flat sequence and locals?
(5,344 Views)
Flat sequences do not give you any options to alter execution. Cannot branch or terminate early. Using wires gives you execution order and using a state machine gives you flexibility. Locals create data copies and often race conditions. Using a local instead of a wire to make 'cleaner' diagrams is just not the correct way.
(5,339 Views)
Just search around this forum and you'll come across dozens and dozens of posts about this. In fact, we've collected a bunch of examples of how local variables have been abused and misused: http://forums.ni.com/t5/BreakPoint/Why-some-people-say-Local-Variables-are-bad/td-p/711239
The regulars here typically see sequence frames used by those who come from a text-based programming background, so they are not using dataflow programming.
(5,337 Views)
Yes, but that's not surprising either, since that's how text-based programming works.  Just like NASCAR folks have trouble making rights.Smiley Very Happy
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
(5,319 Views)
