write to spreadsheet file
All,
  i have written a 2D array to a file using "write to spreadsheet file".
  Now i wanted to add a condition before write happens to file.
let me give small example ,
     suppose i get 1st array element as 10, i should have a condition which checks if it is greater than 11
     then only write to file,otherwise skip the write to file.
Thanks in advance
Praveen
(2,879 Views)
Case structure.
I would recommend going through the tutorial that ships with LabVIEW as well as checking the resources in the NI Developer Learning Center.
(2,868 Views)
The previous advice is right: read the tutorial and examples!
However, in attachment is an example that does what you need.
Nicolas
Message Edited by titi_nicolas on 05-01-2007 07:15 PM
(2,852 Views)
