write to spreadsheet with formatting
Message 11 of 12
(1,298 Views)
(OK, this code is just sceaming to be converted to a proper state machine. Also all these array operations are hair raising. ;))
There is too much distraction going on on your diagram. Could you simply run your VI so the current and voltage arrays contain typical data, then turn them into diagram constants (right-click the terminal...change to constant) and delete all the rest of the code? Save under a new name and attach again. Thanks!
Message 12 of 12
(1,288 Views)
