write to string spreadsheet file.vi
What is not getting installed? VIPM or the individual packages? LabVIEW 7 is supported, but in order to run VIPM you need to install the LabVIEW 8.2 Runtime. I'm guessing that's your problem.
A simply alternative is to use the File/Directory Info function and look at the error code. If you have an error and it's error code 7 it means the file doesn't exist. If there's no error, the file exists.
no...the VIPM is installed in the desktop..but the individuals packages that i download into the VIPM won't install in my labview 7.0..
VIPM will only work with Labview 8.2 Runtime or compatible or else I won't be able to use use VIPM.
but, i'll try going looking at the error code 7 and see if that will work..
thank you guys for helping me out..
Krispiekream
Message 11 of 16
(1,511 Views)
there server is down or something..
i can't install the pacakges in..
it would be easier if i just download to my desktop first and install it after..but the VIPM download and install all at once..
Krispiekream
Message 12 of 16
(1,499 Views)
File Exists__ogtk.vi (18 kb)
the file you give me can only run in labview 7.1
can you make it for labview 7.0?
Krispiekream
Message 13 of 16
(1,495 Views)
Really, now... It's not that difficult to code it up yourself, as I already explained what you needed to do. The actual OpenG function does this:
P.S. Yes, that's the File/Directory Info function. The icon is from LV 8.2.
Message Edited by smercurio_fc on 03-04-2009 03:48 PM
Message 14 of 16
(1,491 Views)
i tried using file/directory info function..
the only thing it give me is the directory info...
the number of files in the directory
and going with the error code...
i recieve no error..
i'll play with it some more..
Message Edited by krispiekream on 03-04-2009 04:24 PM
Krispiekream
Message 15 of 16
(1,481 Views)
yeah..so i managed to do it..
there is a lot of ways to do it though.
i didnt use the "file or directory info" function..
Krispiekream
Message 16 of 16
(1,447 Views)
