write value into the specific cell
Hi to all,
I have a little problem, how can i write a Value into the specific cell? The Value is un txt file looks like this:
Trendschreiberdaten von ARA-Münsterlingen
Gesendet 2009-02-25 14:00:00
SN95279522_LG 123
SN95279523_LG 456
SN95279524_LG 789
and i have to write Value (123) from Device (SNxxxxxxxx_LG) into the Table that have Date (25.02.2009), in Row (Parsingcriteria is SNxxxxxxxx_LG, and that`s not a Problem), and NOW, in Column that have a Haeder defined as a Time (14:00). The Value`s are every 15 min. deliverd and schould be writen in Columns (under the Time defined in Header). In Header are 96 Cell`s where the Time definition is writen (00:15, 00:30, 00:45, ..., 23:45, 00:00). Take look at Attachments.
THX for all your ideas
ID
(2,768 Views)
A table is a special form of a string array.  Just update the array and write it to a local variable of the table.
(2,761 Views)
