writing data from labview to excel
Hi, currently I'm trying to get an array of data from labview into a specific excel file everytime.
The attachment i have is a program creating a new worksheet everytime it runs. I couldn't figure out how to make it work. Anyone can help me?
Message 1 of 9
(3,549 Views)
So what is the specific problem? What is it doing that is incorrect? If the problem is that it is creating a new file every time its because the first subVI is opening a spreadsheet template file. Or at least I think it is since all of the subvis are missing...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 9
(3,540 Views)
Hi Khiam,
  To make it work,you need to install report generation toolkit with proper version.Even i could not able to make it work as there are lot of subvis which are missing.If you have any specific requriement,please post your query.
regards,
SrikrishnaNF
Srikrishna
Message 3 of 9
(3,536 Views)
I do have the sub VIs and i can run the program. The problem is that I need the program to run without changing to a new sheet all the time. I tried to remove the template file and fixed it on one particular excel file but always get an error.
regards.
Message 4 of 9
(3,526 Views)
Srikrishnanf: That's not correct. He's using the Free Excel Toolkit. No need to pay for the report generation toolkit.
Khiam: Take a look here
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 5 of 9
(3,523 Views)
And the error is.......
LabVIEW Champion
Message 6 of 9
(3,515 Views)
Is there any ways to modify the program to open an existing excel file, transfer data to the a worksheet and overwrite the same worksheet everytime i run the program? I do not need the template.xlsx
Message 7 of 9
(3,488 Views)
You said you were getting errors. What were the errors?
Mike...
LabVIEW Champion
Message 8 of 9
(3,464 Views)
I'm sorry people but thanks for your help. I figured the error out and were able to set the data into the same worksheet everytime. Thanks alot for your help and will look for you guys if i need help in the future thanks!
Message 9 of 9
(3,436 Views)
