writing data to a file
I am using the following VI two measure the vibrations. By using the measurment sub VI, I can get the data realted to peak-to-peak voltage and RMS voltage. With the subVI, write to a file, I am able to save the data to a .LVM file. My question is, How can I add the comment to the output file, how can I add the info I want in the header of the .LVM file. I am using PCI-4452 DAQ, and an Ultrasonic Transducer. Looking forward to a reply, thank you.
Nishant
(3,208 Views)
Hi ,
Try converting the express vi to normal vi by right-clicking it and then saying "open front panel".
It will ask you if you would like to convert it , say yes.
Also read this
http://digital.ni.com/public.nsf/allkb/D5049E34AC44EEA549256F1E0075AF26
Hope it helps
regards
CLAD
Using Labview 5.1,6.1,7.1.8.0
(3,198 Views)
Also read the other links given at the bottom of that page
regards
Pooja
CLAD
(3,193 Views)
Thank you for the reply, I will go through the link, Pooja. I will let you know, if i have anymore questions.
Nishant
(3,185 Views)
I did find the URL useful for my VI. My question is, there is some unwanted data in my ecels sheet as the result of my VI. I want to delete that data and change it to according to my requirement.
I colored the unwanted data in yellow,
I want the description in 4 different rows, but now I am getting all in one row... i colored it in red.
I need a suggestion in this reagrd. I am attaching the VI also, thank you.
(3,165 Views)
Hi Nishant,
I could not open your file completely as there were few missing Vis.
Anyways I have solution to your problem
1)For the data in yellow cells. Find the contraol named "File params " this is the control which is writing all the data. try modifying it by getting into the "LVM.vi" that you have made.
Try finding this vi  " ex_HeaderToSprdsheetStr.vi". Try working with this one . I am sure you will be able to do it.
2)For getting data in different rows. Add "End of line constant-" from strings pallette where ever you wish to change your line and concatenate strings.
I hope this helps you out. Let me know the results.
Thanks and Regards
CLAD
(3,157 Views)
Thax for the reply, I will follow the steps you explained. I will let you know if I have any more questions, thank you.
Nishant
(3,141 Views)
