writing defaults to inf file
I want to programatically change some default control values. Searching the forums tells me that the invoke node won't handle changing defaults on a running vi. It looks like using an .inf file will be the best method. I've used this before for storing some path information.
The examples available for writing and reading to .inf shows string, number and boolean.  My question is though, how do I store and retrieve the values in the control, attached (LV8.0)? Particularly the Trigger slope and trigger source controls.
Paul Johnson
Renco Encoders, Inc
Goleta, CA
(2,463 Views)
Its another "Never Mind". I figured it out.
Paul Johnson
Renco Encoders, Inc
Goleta, CA
(2,455 Views)
