writing lpt1
i would like to control a tinsley multiplexer trough lpt port
i trying to write to lpt1 parallele port , but labview send me an error -1073807339
that indicate a timeout i use a 5s timeout but error still there
what i m missing, have you same error with this attached vi ?
vi used in attachement
Best regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,129 Views)
Accepted by topic author tinnitus
Hi if you have not solved this yet. I think your problem is that you have not tied the nACK and or the paper out pin to ground. This is inherent in the port/printer communication protocol
http://digital.ni.com/public.nsf/allkb/B937AC4D8664E37886257206000551CB
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,100 Views)
Hi, try using a while loop for continous writing like this. Otherwise ,the VI that i have uploaded has been tested with out anyproblems.
LabVIEW 8.2,8.6,2009...still learning 😛
(3,091 Views)
thanks yes i remember that this night
because i built only two  port strapping modules for and not for the third  !!!!
thanks
(3,082 Views)
