writing spreadsheet to virtual memory using Digital I/O functions, HELP
Hey Guys,
                    Can anyone give me an example of reading a spreadsheet file and saving it into virtual memory using Digital I/o functions??  I'm having alot of trouble with DAQ in LabVIEW and I'd really appreciate any help i can get.  Thanks alot everyone!!
Philip
(2,425 Views)
Hello Philip,
Some further clarification of your application would be helpful.  Let's first of all make sure that we're on the same page.  A spreadsheet file would not be read using Digital I/O functions.  You can read from a spreadsheet using File I/O functions and then use the data returned to build a digital waveform that could then be output on a Digital I/O board using the NI-DAQmx driver.  The exact implementation for this would be up to you.
If this is what you are trying to do, I would suggest looking in the LabVIEW Example Finder for examples of Digital I/O and File I/O and then combine these to achieve the functionality you want.  I hope this information helps.
(2,412 Views)
