writing string into spreadsheet
i am reading the serial data(in string format) and storing it in text file one by one .but i was not able to write the data in spreadsheet one by one...i am getting the result as last iteration value has been repeated iteration times.....eg If the last iteration value is 5 and it has iterated for 4 times...the output i m getting is 5 5 5 5....but expected result is 2 3 4 5....help me out in ths
Message 1 of 19
(4,942 Views)
Can you please attache your VI. That will be good to understand.
Message 2 of 19
(4,920 Views)
Enable the index in the loop that yu are using to get individual data in . Post a screen shot of what you are trying if possible
Message 3 of 19
(4,907 Views)
My first thought was also that you need to enable Autoindexing.  But that is still a complete shot in the dark without being able to see some code.
Message 4 of 19
(4,903 Views)
I am getting the proper result in wordpad..but i am not getting properly in ms excel.......
Message 5 of 19
(4,882 Views)
i had posted both block diagram nd result
Message 6 of 19
(4,881 Views)
That for loop is just senseless.
Message 7 of 19
(4,870 Views)
if i didnt put for loop than i cant make a string as an array of strings... spreadsheet accept only array of strings
Message 8 of 19
(4,842 Views)
User the build array function.
Message 9 of 19
(4,836 Views)
I see two places that you are writing to.  Which file are you having issues with?  And why are you writing the same thing to two different places?
Message 10 of 19
(4,807 Views)
