I have a PCI6503, a card with 24 DIO lines split between 3 ports, ports A, B and C.
I want to use the PortWrite.vi to write 12 bits at once: all 8 lines of port B, and 4 (lines 0-3) of port C. All 24 lines were configured for output using a single instance of PortConfig.vi (setting port =0, and port width = 24). Can I just send a line map to PortWrite.vi with 24 bits, indicating which lines I want written, ie:
[00000000][11111111][11110000]? I added brackets to emphasize the three different ports.
Of course I could just first configure each port, 1 at a time, then write the 8 bits of port B, and 4 bits of port C. That would be the "simple" solution, but I want the clean solution.
It would be really great if NI would act
ually document these sorts of things, so I don't have to ask them in a forum...
cheers all.
