writing to switches in an event structure from another vi
Been stuck on this for a while, anyone can help??
Below I have attached my vi - alert panel. This is used as a control to trigger different alerts in another vi in the order they occur - where I need to be able to turn each alert off individualy. My panel works great except for the turning switches off from another vi part. I use the data from the queues to trigger alerts, but how do I write back to the switches in the cluster in the event structure to disable the alerts? I tried using globals,which have no effect... Please help,
Alexi
(2,320 Views)
Alexi,
I replied to your previous post about this problem:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=5065000000080000006DCD0000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0
Regards
Anthony Sims
Applications Engineer NI-UK
(2,320 Views)
