I am trying to communicate with a device attached to LPT1 with LabVIEW 6.1 running in Windows 2000.
First I tried directly with the VISA functions using as a resource name ASRL10::INSTR but the VISA WRITE function generates a timeout error (?).
As I couldn�t fix the problem then I tried with the IN PORT and OUT PORT functions in the LabVIEW Advanced pallete: but when I try to write in address 0x378 the OUT PORT function generates the following error: VI Out Port was stopped at Code Interface Node 0x1BC os subVI �Out Port.vi�
I have checked in Windows that the port address is correct, I have logged in as Administrator, so I don�t know why this is happening. Any ideas ?
Thanks a lot.
