writing waveform data to a file
I'm using one of the "getting started" vi's in the IVI examples to try and
get
waveform data from a scope.
The data that comes out of the "fetch waveform" vi's- I would like that as a
pair of x and y coordinates,
in ascii, for a spreadsheet (actually another proprietary program). in the
form
0.0000000e+000
or something close to that.
How do I get there? Do I take initial x, and add the change in x, to get
the x? Then how do I get the
scalar and the y array to print out right?
I've looked at the in stock vi's for quite a while, but none seem to get me
closer.
If I use "build waveform", what does that get me?
How is "build waveform" different from the bundle that brings data to the
waveform graph?
Thanks.
(2,868 Views)
To save a text file with x/y pairs, you have to create an array of time values. One way to do that is to use the build waveform function and wire the waveform array output to the Y input, initial x output to the t0 input, and the x increment output to the dt input. The output of the build waveform function can be wired straight to a waveform graph. To write to a text file as comma or tab separated values, you can use the Get Waveform Time Array function to create an X array. Use the build array function to combine it with the Y array and wire this 2D array to Write to Spreadsheet File.VI from the File I/O palette. You may have to play around with some of the parameters like transpose array and format to get exactly what you want.
(2,868 Views)
Thanks!!!!!!!!!!!!!
"Dennis Knutson" wrote in message
news:506500000005000000135B0000-1011517314000@exchange.ni.com...
te.
(2,868 Views)
