wrong save
Hello!
I accidentally saved my .vi library without saving my individual .vi's, overwriting them - and now i cannot acces the block diagram!
I have the whole .llb as a precaution copy, but i made some changes to my front panel - can i just relink my "front panel" .vi with the other subvi -s?Or just replace this individual subvi?
regards,
Klemen
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(3,276 Views)
Hi klemen,
save the "front panel" vi and all needed subvis into one folder. Then zip all the rest into a safe place. Then open the main vi...
That's maybe not the easiest way, but IMHO the safest.
And please:
Don't use llb in a development environment. Use project-style folders instead! And make backups on a regular interval...
(3,260 Views)
Thank you vrey much for your answer.
I went back to my older .llb and re-did everything I lost; took me about an hour or so (but still wasted time, nevertheless).
I have been using labview on frequent basis for two years now and i am always backing up my work regularly (with more than on copy) - never had any trouble (this was my first somewhat "annoying" problem).
An excellent software, especially when using it with C programming language!!!
Anyway this just shows that no matter how careful you are, you can always make a silly mistake!So think before you act - lesson learned 🙂
Project folders - by that you mean every .vi in its own folder?Do I have to save every .vi or can i do them all at once and then arrange them into seperate folders?
Thank you again,
Klemen
(3,237 Views)
Hi klemen,
for each llb you should use a folder. There's a llb manager that helps you to copy all VIs from one place to the other...
(3,223 Views)
