x axis chart problem
I'm attempting to plot data on a chart with the x axis represented by time. See graphPic1.png for current outcome of my developments. As seen in graphPic1, the data starts plotting at 00:00:16 where ideally it should start at 00:00:00.
I've set the minimum point of the x axis scale range to 0 and have experimented with the x-axis scale property nodes, yet the data still plots from 00:00:16.
I've convinved myself that this is an easy fix but it's driving me mental trying to figure it out.
Stokes
(3,327 Views)
A copy of the code would be handy here I think
"If anyone needs me, I'll be in the Angry Dome!"
(3,321 Views)
Hi Stokes,
Would it be possible that you are timing your VI from the start of execution? If so have you taken into account the time it takes to get to your loop where you read data?
Having a look at your VI would help if this is not the case.
Kind Regards,
Larry Colvin
Associate Principal Engineer
Dyson Technology Ltd.
(3,294 Views)
I agree with Larry, it looks like a synchronization issue. Don't start looping until your initialization is done.
Richard
(3,286 Views)
