x scale elapsed time
I have just recently started using LabView (1 week) and I need some help with the X scale on my charts.  I would like to plot the elapsed time since the beginning of a triggered loop.  I have searched the forms but cannot seem to find a previous post that will help me.  I have attached my block diagram.
I am acquiring two voltage signals thru a NI USB-9219 DAQ and would like to plot the voltages versus elapsed time.  One voltage triggers the case loop once it reaches a threshold value.
Thank you for any help.
Bruce
(3,098 Views)
Hi Brucam,
the DAQ-Assistent already gives you a timestamp. If you use a graph instead of a chart you can display the time starting with zero. You don't need the elapsed time VI.
EmilS
EmilS
(3,077 Views)
Hi EmilS,
Thank you for your answer but, I want to chart the voltage as a function of time and display it as a stripchart.  The graph function does not seem to allow me to do this.  Also, I have two voltages that I am tracking and would like to stack the charts and using a Graph will not allow me to do this.
I am using the elasped time VI as a display right now as it is easier to read than the values on the X-scale of the chart.
Bruce
(3,052 Views)
Hello Brucam,
perhaps you can do it like in the attached vi.
EmilS
(3,040 Views)
